tranny problemmmmm!!!!!
Hello I got 94 Accord EX and I just recently did a tranny flush on it. After about a couple of weeks, the D4 light on my dash board start blinking on and off after driving it for a few minutes. Also I noticed that before when it hit 55mph the tranny downshifted itself like a 5th gear and runned in lower RPM than it is now and gives me a bad gas milage. I changed the solenoids and the Vehicle speed sensor but the light is still blinking and the car still runs with about 2500-2600 RPM in 55mph.. does someone have any idea if this is a electrical problem or?? anyone got problem like mine? do u know how to fix this??
Thanks |
RE: tranny problemmmmm!!!!!
the big important question is, what fluid did you use when you refilled the tranny.?
lightshow |
Honda tranny fluid.
well thats the good stuff. there are some other people on here that are having problems with their trannies and the VSS seams to be at fault, this could easily be your problem.
lightshow |
already changed it but nowthing happened. it is the same :(
did you change the mechanical part with the gear or the eletrical part on the top of the tranny?
lightshow |
i think is the electrical part
did you change it or did someone else? you wouldnt have mistaken a huge gear hanging out of the bottom.
