Transmission Coolers
I have a 02 EX V6...new tranny last april. What transmission cooler should I get? Also how hard are these to install?
RE: Transmission Coolers
Hayden 403 ..... zip ties at minimum.
Oh, come on. Spend the $2 for metal hose clamps.
I meant to mount it. I think it actually comes with zip ties.
Ahh... okay then.
Is it worth spending the money on a B&M cooler or one made specifically for the this Gen Honda??
Nah, a coil is a coil. The Hayden 403 fits right from what I read when I had a 6th gen V6. In this case, bigger is better but you still have to mount the thing. Also, make sure that it gets a good breeze across it to improve it's efficiency.
I don't see where it's worth the expense. You don't tow or subject the tranny to high heat so why bother? The 6th gen auto trannies are know to be, uh, lacking in longevity so where is the gain for the money spent?
Originally Posted by RTexasF
(Post 152809)
The 90's gen Mopar transmissions failed due to lack of tranny fluid capacity. Little tranny fluid = poor heat dissipation which = transmission failure. -80k miles the tranny overheated and went into safemode on a trip to TN. -After we rented a car and came back my dad put a tranny cooler on. -Car now has over 180k miles and doesn't slip and still runs strong. W/o the tranny cooler it would have been dead long ago. Not to mention those v6's are torquey as heck and they can still spin the tires w/o a problem. You dont need a large one, however like stated, the bigger the better. Remember you need to add a bit of tranny fluid to make up for the extra tubing you are adding. If I remember correctly, you want the fluid to go through the cooler right before it enters the tranny so the radiator doesn't heat the fluid back up. Also, in winters, you will have to let your transmission fluid warm up a minute or two before it engages in gear. When I have to move my dads car I put it in neutral so it warms up faster. |
You have a valid point. In an auto where the tranny naturally runs quite hot it can be a lifesaver. I suppose it can't hurt and would increase the fluid capacity slightly. For very cold temperatures a bypass to the cooler might be in order.
