Trying to order new ECT Switch A and B... not sure which parts match
Hi,
I'm trying to order a new Engine Coolant Temperature Switch A (located on thermostat) and Engine Coolant Temperature Switch B (located next to manifold on lower hose I believe). I've been searching for hours on different parts sites, but none indicate which is which... It'd be super helpful if someone could tell me which of these would work for Switch A and Switch B. Are they even different?? RockAuto Parts Catalog (give it a few seconds to load) Thanks! |
None of those are correct part. Those are temperature sensors. You need radiator fan switch (RockAuto Parts Catalog). It fits on thermostat housing.
good luck |
Thanks. I was able to find the part numbers and search that way. You are right, they are the radiator switches. :)
