undercrank Pulley
can you guys help me out with this one? i dun really get how undercrank pulley works. and i saw urthodox brand undercrank pulley on ebay. how many do i need? and do i also need to buy the belt? and does it have its brand name on the pulley? thanks!
RE: undercrank Pulley
Are you talking about an underDRIVE pulley? It's smaller than stock, so it drives all your accessories at a little slower speed. Then those accessories take a little less HP away from the engine.
The accessory drives are made so that they work normal at idle. With an underdrive pulley you may notice a bit less boost to the power steering at idle, a bit less power from the alternator at idle, etc. If you spend all your time driving & not idling, maybe that's OK. |
UR does have it's name on the pulleys and the kit comes with replacement belts.
