v6 engine swap
this is my first post but i have done a fair amount of mods to my 2000 honda accord lx and 4cyl. and i was wondering how hard it is to do a v-6 engine that i will turbocharge before putting in and swithching the trans to manuel but are the connections for the all the plugs and wiring and that kind of stuff the same or not...also i haev not been to see what kind of wheel horsepower that people are putting out with a turbocharged v-6...thanks
RE: v6 engine swap
It's been covered before, you're betting off eithergetting an H22, converting your car to manual, or turbocharge the F23.
RE: v6 engine swap
ORIGINAL: BlkCurrantKord It's been covered before, you're betting off eithergetting an H22, converting your car to manual, or turbocharge the F23. The conversion from auto to manual is hard enough on a 4cyl. I know the 98-02 V6 cars were not even offered in manual trans, so I have no Idea what transmission would match up to that V6. Unless you plan on taking a V6 with manual trans out of an 03 or newer model. And in that case, I have no idea if it would even fit. Most H22's put out about the same hp as the 98-02 V6 (200), not as much torque though. |
