valve lash?
What are the specs for valve lash on a 1986 accord dx, 2.0 2bbl carderated 12 valve, manual trans?
Should be on the sticker under the hood.
COLD ENGINE - Intake is .12-.17 MM or .005- to .007 inch.....Exhaust .25 to .30 MM or .010 to .012 inch....double check my metric conversion Be sure each is checked when each cyl is at TDC. I find it easier to remove the spark plugs, so there is no compression to fight. Again....cold cyl head. |
