vtec dohc on f22
ok so im pretty good with hondas but dont know much about the accords. i was wondering if there was a vtec dohc head that would fit on the f22a1 block? im trying to get a little more power without completely swapping the engine. any help would be greatly appreciated.
Im pretty sure that version of vtec is economy vtec not powermaking vtec so it probably wouldn't be much of a gain. If you're interested in a head swap take a look at the g23 build, its an f series engine with an h series head.
i would just go without the vtec do the cam if ur thinking bout boosting the vtec will add more compression and u will only be able to use a smaller turbo
not really wanting to boost... what all would be involved in doing to g23 thing... ive never heard of that
heres a couple websites ive found cause i was in the process of doin the g23 swap.
http://www.cb7tuner.com/vbb/showthre...ight=g23+build http://www.cb7tuner.com/vbb/showthread.php?t=100957 http://www.importtuner.com/tech/impp...dge/index.html http://hondaswap.com/prelude/f22bloc...th-gen-214232/ http://www.honda-tech.com/showthread.php?t=1046336 hopefully that will help u out a little bit |
