h23 in 92' 4door
h23 in 92' 4door
I want to attempt to put an h23 in my accord,but i dont know exactly all the parts or modifations i might need 2 do or make(axles,motormounts,cpu,wiring harness..Is there any body out there could help me out with any info on this swap????
RE: h23 in 92' 4door
Axles - reuse yours (I'm assuming you're manual)
Mounts - may need the prelude's driverside mount, the others should bolt up fine.
CPU- P06? (double check that)
Wiring - maybe have to extend a few wires here and there...shouldn't be too hard.
www.cb7tuner.com ...your one stop for everything you need to know about the 90-93 accords
