want to paint
im looking to remove the cover that has the Honda emblem [H] & says V-Tec on it, but im not sure which gasket i would have to replace? (sorry, im not used to working with I4's).
________ Penny stocks to watch |
RE: want to paint "vtec" portion of the motor
valve cover gasket and you might as well do your spark plug seals as well (if the car has them... just ask the parts store)
and you only need to replace them if the rubber gasket for the valve cover has cracks and is falling apart, otherwise you dont really need to replace anything
Hello New Member..Thanks for joining up with the HAF..we are one of the best..
In response to one of the things to do about your car is this..If you are going to become a concious maintenance person on your Honda, then by all means don't ever do 1/2 of the job, do it all 100% right..replace what ever you take off with new and also anything that goes along with it..Then The Job Will Become Correctly Done Right... WheelBrokerAng[sm=americanasmiley.gif] |
