Warning lights 2010 accord
I have a 2010 Accord that has several dashboard warning indicators lit: VSA, BRAKE, "D" in drive is blinking, and the ABS warning is on. Last time this occurred, the mechanic replaced a computer. That solved the problem for about a month, it returned intermittently, and now it is back full-time. The car was in a front-end collision in 2011, and everything was repaired with OEM parts. Car is drivable, but the lights are annoying. Anybody know what might be wrong with this vehicle?
They may not be related except that ABS and VSA use common inputs.
Suggest getting ABS/VSA codes w/ following link. Forgot the link: http://forums.clubrsx.com/showthread.php?t=636707 Brake light could be low brake fluid or stuck brake reservoir float. Suggest disconnecting brake reservoir float switch connector and see if light goes off. "D" light blinking indicates a trans code is set. Get and obd2 scan at auto parts store to see what's stored. Post back your results for help. good luck |
Thanks for the ideas, TexasHonda. I'll look at these things tomorrow morning first thing. I'll ask about the obd2 scan thing as well. Better to be prepared before taking the vehicle back to the Dealer.
