Weird Sound
hey everyone i wanted to see if u guys can help me out, today i had one of my tie rods changed because it squeaked on my suspension(fixed) but i noticed that i still have some otheer squeak when i let go of the pedal/accelerator everytime i press it and let it go i hear a squeak as if something needed lubrication or something and everytime i go on the road and the gears change i hear a short squeak too. any help would be appreciated.
RE: Weird Sound
If the sound only happens when you accelerate or shift gears, it might be a trans or engine mount bushings. When you accelerate or shift gears, the engine and transmission actually move. They move on thier mount bushings, if these bushings are worn out you might have some noises. Do you ever have any sounds when you turn, hit bumps, etc?
RE: Weird Sound
yeah man when i hit bumps i have heard squeaks also when its shifts gears, however i have not heard squeaks when going thru bumps now since my suspension tie rod got fixed, but i still hear a light to medium squeak when i press and let go of the accelerator, i will go tomorrow and have the mechanic check the engine/trans mount bushings.
RE: Weird Sound
thanks for ur advice agent of darkness!
| All times are GMT -5. The time now is 09:30 AM. |
