What Fuel injector do you use?
Just wondering what fuel injector cleaner you guys use and how often do you use it.
Thanks. |
RE: What Fuel injector do you use?
This is what I use now: http://lubecontrol.com/ (FP60) but Chevron's Techron is among the best for over the counter purchase. Fuel Power is added to every tank @ 1ounce per 5 gallons. I used Techron roughly every 3000 miles or if I noticed a rough idle, whichever came first. For the Techron get the large bottle that treats 20 gallons, pour it in and fill 'er up!
The Fuel Power is more than just a cleaner. Many people enjoy higher miles per gallon with use. Our '03 Corolla gained 2.5 MPG over several tanks and is now consistant at that level. My '04 Accord 2.4 5 speed manual gained 1.5 MPG after two tanks of fuel and is now constant at that level. |
Thank you for the information. Question, by using these products, does this eliminate having to have the injectors cleaned periodically by a mechanic (assuming rough idle/decreased fuel mileage, etc. is not a factor)?
Hi Again..
I personally use Lucas Products for my cars..they have about 20 different products on the market and most of their products seem to work very well. I add about every 5,000 miles on the injector fuel... Now you have more porducts to research... WheelBrokerAng |
I have never had to take a fuel injected car in for cleaning/flushing so the answer is yes. By keeping the injectors clean there should be no need for other servicing.
Thanks again-it's nice to have someone reccomend products they have used with success-I will check these products out.
Lucas products are world wide and universally accepted. They make a terrific fuel system cleaner.
