-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   What is function of circlip on end of axle shaft? (https://www.hondaaccordforum.com/forum/engine-internal-11/what-function-circlip-end-axle-shaft-14644/)
razcob 12-12-2007 04:15 PM
Replaced the seal between the driver's side axle and transmission. What is the function of the circlip that is attached the transmission side of the axle?
Chiovnidca 12-13-2007 11:35 AM
RE: What is function of circlip on end of axle shaft?
Didnn't leave it out did you? It holds the axle in the trans.
razcob 12-13-2007 07:29 PM
No, but I noticed that the clip on the new axle wasn't a perfect circle, unlike the old axles' circlip which is a perfect circle. I couldn't get the axles in, unless I replaced the new clipswith the old circlip. Honda cautions about ensuring that it is replaced. The old clip (95 EX, auto, w/120K) didn't look worn at all.
