what is a good price for a used manual transmission?
looking for a used manual tranny for my car to swap out the automatic, but i dont want to overpay for one either...
im probablly gonna go to the junkyard and find one that's in good condition to buy |
RE: what is a good price for a used manual transmission?
Have you looked into all that you need for the swap? You can't just put in the transmission and go... theres a million parts you need!
can you tell me what i need?
ive never done this before |
Nor have I because of the intensity of the project... you need transmission, gearbox, new sensors, clutch pedal, linkages, etc etc etc...
shift knob, shift boot, and do i have to change the gauges?
since the gauges for the automatic are different from the manual |
ORIGINAL: thunder_x can you tell me what i need? ive never done this before but as for what you need manual tranny of course, pedals assembly , clutch master + slave cylinders, hydraulic lines, shif rods, different computer, clutch kit, flywheel, different center console, etc etc ... http://honda-tech.com/zerothread/1237137 read up on this ,, it will give you a better idea |
cool, thanks
wow..
that is a lot of stuff to get, how much do you think it will cost total? parts and labor? someone on this civic forum said he swapped his for 800 parts and labor, that's unbeliveable |
Parts maybe... definitely not labour... if you got someone to do it (if you can find a mechanic that will) it'll come up to about $2000 and personally, for that much money I'd rather go turbo!
labor is cheap when you do it or if you have friends to do it
