What things can u do to modified an engine and tranny.
I know this is a lame question...
what can u modified with out openingthe engine... not the internals.. like bolt on pieces for example.... tranny fly wheel clutch l.s.d engine pullys underdrive pullies cam gear.. intake header cat exhaust distibuter cap fuel rail fuel injecters. manifold ecu Iono so wat else just wondering thanks guys i know its lame... |
RE: What things can u do to modified an engine and tranny.
Are you talking about everything but internal engine mods such as pistons, rods, bigger bore, etc.??? I really have no idea what your asking
Nah Im sorry im just talking about simple mods...
Im not talking bout opening da engine... just simple things... sorry guys.. |
Easy:
Cold air intake, and if you want to get fancy, Ram air. Complete exhaust, you usually get the best pipe sizing from manufactures instead of muffler shops. Intermediate: Upgrade ignition (can someone explain?) Like better wires, plugs, ect. Better clutch, or even stage 2. Lighter weight flywheel. Hard: Turbo. I'm sure there are a lot more. I noticed in your post that you mentioned a cam. This I would consider as taking the motor apart, but if you can take the head off, I would rebuild it! Port and polish the head, get brand new valves, dual rate springs, roller rockers (if honda's have this kind of valve setup), bigger cam, and an adjustable cam gear. |
Is the point not having to pull your engine, or not having to machine the block??
In Small block chevy's, I know it's not advisable to ugprade the top end without bringing the bottom end up to standard, but I don't now about forein cars. |
Yea i dont wanna pull the engine out...
i just want the simple things... i know the internals are more of a pain in the butt... yea you answer helped me out thanks nova... so why is it good to port polish the heads n other things.. |
I would suggest..
Searching b/c you're not really asking anything that hasn't already been asked before, and brushing up on your grammar cuz I can't understand anything you typed. |
Yes but if u was too think about it every topic has been cover before...
So wats da point of asking... If searching was the whole thing why are we here.. im just askiing for help thank u.... My grammer is always a problem im not perfect but im trying... all im trying to say simple modifications without having to take the engine out.. simple modifications that will add horsepower... anything that can be replace without taking my engine out... |
All you're asking about are the basic boltons. Trust me, they've all been covered. Exactly, what is the point of asking about something thats been asked 20 million times already.
every bolt on has been covered on just about every site, bolt ons are simple..... hence the reason theyve been covered and beaten to death...... the point of asking is to ask something that no ones asked hundreds of times already and theres only a small amount of bolt-ons that can be done to increase power without taking apart the engine and/or turboing and having solid engine management.... but thank you for creating another thread thats the same as many others on the site ^_-
