-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   wont start in hot weather (https://www.hondaaccordforum.com/forum/engine-internal-11/wont-start-hot-weather-10416/)
99cummins 06-19-2007 04:20 PM
today it was probably 85 and raining so i couldnt put the windows down. went out to start the car after work and all it would do is turn over as if it wasnt getting fuel or spark. the kid i bought it from had this problem last summer but this is the first for me. i usually put the windows down halfway through the day so it doesnt get so hot. any
any ideas would be appreciated thanks
JimBlake 06-19-2007 05:02 PM
RE: wont start in hot weather
Main relay comes to mind when you say the cabin was really hot.
Some have bad solder joints, if you know how to solder it's easy to fix them.
99cummins 06-19-2007 06:09 PM
will it still turn over if the main relay isnt working??
where do i find it
JimBlake 06-19-2007 10:57 PM
If the main relay was bad, the starter would still turn over the engine. The main relay switches the fuel pump (among other things) so it wouldn't get any fuel.
Check this out...
http://techauto.te.funpic.org/mainrelay.php
It's a little weak about exactly where to find it, but Honda always seems to put the main relay sorta above thedriver'sleft kickpanel.
99cummins 06-20-2007 05:02 AM
ill try fixing that tonight
thanks alot!
ducatiff 06-25-2007 09:59 AM
Main relay is the problem. I had it happen to my 90. If you it happens and you are in a pinch, turn the car on and crank the engine and at the same time pop the underside of the dash with your palm, sometime that will switch the relay to get it going. I bought a new one from Honda because if happened to my wife and lets just say she wasn't happy. I think it was like $135bucks from Honda though.
