"A whole lotta shaken going on" 04 accord
I'm getting a lot of vibes when driving down the highway but only when the car is cold. After it warms up, it's fine. I first suspected the tires but I just put new tires on (because of wear not vides). Could it be something to do with the axles or bearings? The car has about 80K.
Please advise
Thanks
Hank
Please advise
Thanks
Hank
go into a parking lot and do slow circles as tight as possible and listen for a clicking noise (cv test) if there is none then at least you ruled that out.... it only does it when it's cold? does speed matter or will it do it just idling too? If it does it all the time, when did you last do a full tune up (plugs, wires, cap, rotor, fuel filter etc....)
I only notice it as I'm starting from a dead stop until about 3-5 miles down the road. Then it clears up and drives normally. I'll do as advised to check the cv axles tonight. I haven't done any tune up as of yet. I really didn't think I needed to with only 80K but hey, it probably wouldn't hurt.
Anymore thoughts?
Anymore thoughts?
