[HONDA ACCORD 06] HELP! PLEASE. My signal has been a problem. If you could help!
Hello,
My signal is doing something very weird. From time to time, especially when the car is under the sunlight for a long time, when I try to turn the signal on nothing happens. When this happens, you must notice the dashboard light dims when you turn you head light on, dashboard does not go dim. But hazard light does work at all times. And if I let it cool down or turn the engine off for some time, everything is back to normal. Would this be the turn signal relay problem? If it is is there any online store you recommend? Thank you so much!! |
Thank you!
I'll try replacing it and let you know how it worked out!
Thanks! |
