'00 Accord V6 Headlight Problem... Fuse?
Hey all. Man it's been quite a while since of been on this site. i recently bought a house and have completely let my car slip into a tired state!
Anyway, my headlight kept going out about once a monthsoI had my buddy check the voltage. After that no bulb that I put in there will work! I bought a brand new bulb and everything. I looked at the fuse box and didn't see a fuse for headlights. Only ones for turn lights and daylights and backup lights(???). Does anyone know if there is another spot where the headlight fuse may be? Or have any insight on this problem? Thanks. |
RE: '00 Accord V6 Headlight Problem... Fuse?
If I had that kind of problem, I'd wire a relay setup and cut the OEM headlight wire from the harness, then use it to trigger the relay. Seamless change, but5 now the headlight power comes straight off of the battery.
