02 accord sputtering issue
I have a 02 accord se vtec 2.3 with 126k miles it started kinda puffing or poping or whatever it's called at idle after it's driven a little we have put new plugs oil change cleaned erg and fuel injectors no help at all it has between 150 and 160 psi compression on all 4 cylinders no check engine light is on we used auto lite platinum plugs
I have no experience with auto lite plugs. Most people recommend NGK brand or Denso brand plugs for Honda vehicles. Take a look at the sticker under the hood or the owner's manual for the proper plug.
Since the problem remains, the plugs are not likely the problem. Please give more detail about the problem. Does this happen right after the car reaches operating temperature? Not sure what you mean by puffing/popping. Does it happen at a certain rpm, speed, or gear?
You may want to stop by a parts store and have them check for codes anyway. Some transmission codes would not cause the D4 light to flash on older hondas. This may be the case with your 02 accord as well.
What cylinders are misfiring; all (P0300) or specific cylinder code (P0301-P0304).
Suggest first confirming that all 4 spark leads are firing using an old spark plug grounded to frame and testing each lead.
anandram
07-05-2010 11:05 PM
B1ackKn1ght1979
10-01-2007 12:17 PM
