02 Starter removal
I have a 2001 honda accord lx 4 door. Its got the 2.3l motor in it.I am trying to removel teh starter.I can see it an remove most of the bolts but it seems to be held on by one other but i cant find it. Does anyone know of a bolt ont he back side of the starter an if so where an the easiest way to get to it an remove it. Thank you in advance for any kind of help..
RE: 02 Starter removal
The starter is held on by three mounting bolts, the power cable, and relay wire. The last mounting bolt is on the lower side of the starter toward the fire wall. Feel around in there and you will feel its head, but you might need a breaker bar to get it loose. I did....
| All times are GMT -5. The time now is 05:13 AM. |
