-   -   03 accord oil issue (https://www.hondaaccordforum.com/forum/general-tech-help-7/03-accord-oil-issue-48964/)
Honda5280 Jul 19, 2012 02:39 PM
03 accord oil issue
2003 accord LX with 104,500 miles
I am loosing oil. (within 1200 miles of oil change - full to less than quart) The check oil light does come on, especially when I brake hard or fast. I turn off and re-start engine and the light goes off
There is no spotting on the driveway, nor burning smoke. There is stainage on the engine (left side if looking at it)
I took it to two different places. One had no explanation, the other "thinks" its a gasket issue and could cost $350.00
Other than taking to Honda, anyone else have this problem?
thanks in advance.
UhOh Jul 19, 2012 03:16 PM
welcome to forum
Originally Posted by Honda5280 (Post 289864)
I am loosing oil. (within 1200 miles of oil change - full to less than quart).
clarify - is this right?
~4qts oil capacity at change and you lose 3 qts in 1200 miles?
generally, beyond big drip evidence, I'd have someone else drive it and you follow behind to observe.
but maybe you've done this.
best
Honda5280 Jul 19, 2012 03:33 PM
Thanks,
That is correct, have troubleshot with your suggestion. Nothing. I'm at a loss. I'm concerned that it's gonna cost $ to diagnose and now isn't the right time for that.
Dr. Drivability Jul 19, 2012 04:01 PM
if it's not leaking, it has to be going somewhere, that's excessive for 1200 mile...have you pulled the plugs and checked condition? my 03 2.4L with 180k, uses about a quart every 2500 miles or so. something is wrong....
JimBlake Jul 19, 2012 04:53 PM
Note that the whole range on the dipstick (min to max marks) is about 1 quart. It doesn't have to drop too far below the minimum mark before it's completely off the dipstick.
Honda5280 Jul 19, 2012 07:20 PM
Thank you, I will check the condition of the plugs and get back to the thread. I will note, that when cold, the oil comes to the tip of the dipstick, when hot there is nothing.
UhOh Jul 20, 2012 01:42 AM
We're here to learn, and not being judgmental:
most of us with oil problem would check oil frequently and add when it reaches 1/2 qt lower than full.
Sounds to me like it's normal operation is maybe 2 qts low.
Checking out - don't think I can add anything.
poorman212 Jul 20, 2012 08:10 PM
Pic's of "stain" might help.
So cold, the level reads correct but when hot and 3~5 minutes after shut off, there is no reading on the stick?
JimBlake Jul 23, 2012 08:10 AM
To me it sounds like there's a little oil on the tip of the dipstick when he checks it cold. That's a bit low, but I don't have the 2003 car any more. Seems to me the dipstick has a couple mm extra length below the "low" mark. So maybe it's a pint below the "low" mark. Need to add oil but maybe don't need to panic about damaged engine.
