04 Honda Accord
Hello, new to the forums. I have a 04 honda accord 4cyl auto. Last night driving home after going up a hill, i pulled into my driveway and had a very rough idle with the break on and in drive almost wanted to stall. Rpms were around 600-700, i set the E-brake and left it in drive and could periodically see the belt tensioner move and make a clicking sound, got worse if i turned on the heat. The cel light started flashing and went off a couple seconds after i put it in neutral and the idle was normal. So i put it in drive again with the rough idle and drove around the block back into my driveway and all the symptoms were gone:shrug: Ive had the rough idle/shaking symptoms before after some rough city driving but never the cel light come on because of it and it always went away. On a side not earlier this month i got the code p0171 System Too Lean (Bank 1) cel only when it was really cold outside and on warmer days would not come on, i found my throttle body intake hose was cracked bad underneath, i replaced that and the air filter disconnected the battery and the light has not come on since then. Anyway these 2 symptoms are related? Thanks
The auto-tensioner should not be moving with the car running. The tensioner and belt may need to be replaced. It will affect the charging system.
The earlier P0171 should be unrelated. |
Thanks for your input redbull. I was actually just watching a video posted on this site about changing the belt. Its does seem sluggish to try to start in cold weather even with a new battery and starter. Do you think this might be the cause of the rough idle almost want to stall under heavy driving conditions periodically? thanks. oh the auto-tensioner only does that when the symptoms i described above happen. car currently has 166,000 mile give or take
Under load, the alternator/charging system output should be higher; so, a bad tensioner and/or belt can affect the idle and other things.
That makes sense, i did inspect the belt for wear, looked normal but could be stretched, tension seems tight by hand. I think i will go with replacing the belt and tensioner, as you mentioned seeing i bought this car with 110k on it, i have no idea when they were replaced and i have put 56k miles on it so far in 2 years, mainly highway. Any links on here for replacing the tensioner you know being a Super Moderator? Looking at it, it seems only a couple bolts. You've been very helpfull
See link:
