05 CEL reset?
On my 05 Accord I had an engine code and think I have fixed the problem and want to reset the CEL to see if I actually did fix it. On my 99 you pull fuse #13 (clock/back up) in the panel on the passenger side. Is it the same for the 05?
1 Attachment(s)
You can try pulling the ECU fuse, #8 (15A) located in the under-hood fuse/relay box for several minutes.
Or you can go to an autozone/advanced auto and they might clear it for you(they aren't supposed to but many do).
Beginning in 2003 they use non-volatile memory so disconnecting the battery will not clear it.
Whether or no parts stores will clear it for you seems to differ state-to-state. I've had them do it here in Ohio. Stories about them refusing to clear it seem to come from California. |
Curious, what was the code and what did you fix/replace?
Code 1457
Replaced the gas cap and so far so good. Most auto places around me won't reset the code due to liability crap. |
Yup, that code is related to the EVAP system, loose, bad or missing fuel cap, just an FYI, Honda has replaced that code with P0457.
