05 Radio Problems
I have a 2005 4 door sedan 2.0 MT. The radio would cut out so i replaced fuse. Radio then worked for a short time and then went out again. I then would just take out fuse and then put it back in. It would work for a while and I would just repeat process. Now it won't work at all. Has anyone had the same problem?
You can try to check the electrical connector for the radio.
It sounds more like a problem with the radio itself. Alpine makes the radio in the US for the 05 Accords. They repair factory radios for a much lower cost than buying from the dealership. Having a 2.0L places you outside the US, so you may want to find out if/where they could service your radio. Do the heating and a/c controls work properly? |
