06 vs 07 engine wiring harness
So I'm putting a motor in a 06 accord v6 2 door. I got an engine from the wrecking yard that's from an 07. It came with the whole engine wiring harness, throttle body ect all still in tact on the motor. My question is will it be plug and play? Is the 06 and 07 wiring harnesses the same or will the connectors be different? Thanks.
It "should be" plug and play - I have to admit the manuals I have don't cover the '07 - for some reason they "jump" from '06 to '08?
Hopefully the fact that they skip 07 means its the same as 06
Honda parts diagrams at online Honda dealer's site show V6 engine harnesses to be identical for respective engine/transmission. You can check yourself at online sites like Bernardi Honda, Honda Parts Now, Majestic, etc. for the engine harnesses.
Technical service information available electronically doesn't skip years. Info. for 06 and 07 Accords are relatively the same. |
