07 accord 2.4 code 1157
Old 03-07-2019, 03:55 PM
07honjohn's Avatar
Default 07 accord 2.4 code 1157
After the car warms up the check engine came on p1157 I replaced the 02 sensor light came back on just like before nothing changed but the old 02 sensor tip was white and chalky like it was leaned out i pulled the spark plugs same thing with them.so i replaced them and coil packs and the fuel injectors where do i go from here. Thanks
Old 03-07-2019, 04:33 PM
Seanjordan20's Avatar
Was it a denso sensor or another brand. If not then buy a denso and check the plug/cable while you're at it.
Old 03-07-2019, 04:42 PM
The Toecutter's Avatar
Isn't a code 1157 something to do with the EVAP system? Or am I thinking about a different model/code?
Old 03-07-2019, 04:50 PM
No it's a sensor 1 code. Usually a new sensor fixes it but there is a possibility of the harness being open/shorted.
Old 03-07-2019, 04:55 PM
He should of had to replace the sensor that is connected on the right rear of the engine. It's mounted just behind the oil pan on the pipe.
Old 03-08-2019, 08:02 AM
07honjohn's Avatar
yes it was a denso the harness and wirning look good all the way to the firewall
Old 03-08-2019, 08:17 AM
Unplug your battery and touch the 2 cables together for 5 mins to force a reset. Then try again.
Old 03-08-2019, 08:22 AM
You may need to return the sensor due to it being faulty. Make sure you have the right one installed. Denso 2349040
Old 03-08-2019, 04:43 PM
07honjohn's Avatar
Default 07 accord
I done the reset it didnt do anything.ill check the 02 sensor part number in the morning.thsnks for the replys.could the ecu be sending a faulty signal.and if i get a used one one could it be programmed to my car
Old 03-08-2019, 04:59 PM
Did you replace the sensor that bolts into the catalytic converter, or the sensor that is upstream of the converter?
Do you have any testing tools like a scanner or volt meter, etc.?
Quick Reply: 07 accord 2.4 code 1157
