07 Accord wont start unless door is opened and closed
okay guys, i have a strange problem im trying to fix for my sister. She has a 2007 Honda accord. When you put the key in the ignition the dash lights come on and the car beeps like normal, but when you try to crank it, it makes fast clicks like the batter is dead. if you open and close the door, it ill crank right up. Any ideas what could be causing this. Where to look if its electrical. im stumped on this one . :confused::confused::confused::confused::confused: :confused:
Thanks |
First thing I would do I clean all ends of both battery cable, while they are off a good time to have the battery tested.
Be sure when they go back they are clean and tight |
