08 accord help, trying to find dome light wires
I'm trying to wire leds to turn on and off with the dome light. I just need to kniw where the pis and neg are plus there colors. Anybody???????
pink and green, the dome lights are controlled throught the multiplex unit...hope you don't blow that up...bery spensive ;)
Originally Posted by Dr. Drivability
(Post 289735)
pink and green, the dome lights are controlled throught the multiplex unit...hope you don't blow that up...very expensive ;)
Anybody know where and what color the dome light pos and neg are? Want to wire leds to turn on and off with dome lights. Just need to know where to tap into those wires.. anybody know???
Green is one of the positive wires (green probably is the wire for pin terminal 1 on the ceiling light electrical connector). Pin terminal 3 should be the ground wire. It didn't specify the wire color for terminal 3 (ground); but, should be Black.
The terminal pins are 1, 2, and 3 (with terminal 1 closest to the tab on the connector). Disclaimer: This is just for informational purposes. Any modifications would be at your own risk. |
Ok thanks for the help :] I'll post my results
I tapped green wire with circuit tester and bulb lights up. When I shut the doors dome light goes off but circuit tester bulb stays on. Why won't it turn off with dome??
Can you help me understand why I can't get leds to go off with dome light? Used a circuit tester and poked green wire right behind dome light, when door is open dome light and circuit tester bulb stay lit. When door is shut, dome goes off and circuit tester bulb stays lit. Do I have to tap it near the mutiplex to get it to turn off with dome light? Any help greatly appreciated
When you do that, where are you grounding the test light? Honda's traditional way of doing things is for the (+) wire to be hot all the time, & the ground wire is switched.
4 Attachment(s)
The dome light and the map lights are negative trigger from the door switches, each door switch wire run to the Multiplex Integrated Control Unit (MICU) located in the under-dash fuse/relay box. If you connect the ground source wire from your LEDs to the wire from the MICU, it will trigger your LEDs to come on when a door is open and shut off with the doors closed after a brief period.
The ground source wire coming from the MICU is a pink wire at terminal pin no. 12, located at Connector 501. Note: Do at your own risk. https://www.hondaaccordforum.com/for...1&d=1481561485 https://www.hondaaccordforum.com/for...2&d=1481561485 |
