PAhonda |
01-08-2010 08:35 PM |
There should be two fuses, one for each of the low beams. Those fuses are probably in the fuse box under the driver's side of the dash. Check those first to see if they aren't both blown.
If not, then see if you have 12V on the wire at the low beam bulb plug (it should be the non-black wire) when you have the low beams turned on. This will determine if the problem is with the power side of the circuit or the ground side. Just grab a volt meter, and touch the red probe to the non-black pin, and the black probe to a bolt on the valve cover.
