-   -   1990 Accord exi stalling when coming to stop (https://www.hondaaccordforum.com/forum/general-tech-help-7/1990-accord-exi-stalling-when-coming-stop-36065/)
dave snelling Nov 11, 2010 09:33 PM
hi, my 1st post. ive searched the site and have founhd some great information on stalling however not anything to do with my exact problem.
the car will start, run fine at revs then when you pull up at an intersection it will stall , everytime. things i have already replaced include..
fuel pump, ecu, low idle valve, ignition switch , throttle body and sensor, coil in distributer, exaust 02 sensor. also changed plugs/leads and reset timing.
thanks for any help in advance
Dave
(Australia)
poorman212 Nov 11, 2010 09:55 PM
Does this happen when the car is warm, warm=normal temp of the engine. Cold it acts fine, once to normal op temp the problem happens?
maachan513 Nov 11, 2010 10:12 PM
Have you checked for faulty brake booster? Have you tried to stop with e-brake only? Just for testing purpose only, you know. Do it in vacant lot.
dave snelling Nov 12, 2010 01:02 AM
thanks for the responses ,
happens when car is any temp
went for a test drive after removing radio/backup fuse for a few minutes.
used the emergency (handbrake) only
still same problem.
PAhonda Nov 12, 2010 01:14 AM
This is pretty weird. Try putting the car in neutral and try the brake pedal to stop the car. Also try putting it into neutral and use the e-brake.
You can also try checking for error codes. Look at DIY section for how to check cel codes.
maachan513 Nov 12, 2010 05:25 AM
What is your idle speed/RPM?
IAC valve? Out of adjustment on Idle screw?
dave snelling Nov 12, 2010 05:24 PM
is there away of checking o.2 sensor front of engine at manifold
TexasHonda Nov 12, 2010 06:04 PM
When started, will engine idle steadily at 700-800 rpm warm or 1000-1500 rpm cold?
If yes, then something may be happening w/ the transmission to stall the engine. The lock-up torque converter can refuse to disengage, causing the engine to stall. Very similar to a manual shift car coming to a stop w/o engaging clutch.
Suggest shorting the service check connector, and reading the D4 or S light flashes for codes. Some trans codes don't automatically set D4 or S flashing.
dave snelling Nov 13, 2010 10:46 PM
thanks everyone for the help so far..
have now test driven car and stopped with foot brake and then emergency brake whilst car is in neutral. no change
removed exaust manifold shroud to check for another sensor. no extra sensors
re checked ecu and tcu for error codes on instrument display
ecu check - engine light comes on and remains on when blue connector is bridged
tcu check- no lights come on on D4 display.
