1991 Accord EX Freeze Plug Location?
I am trying to find the location of the freeze plug on my 1991 Honda Accord EX 4 door sedan, 5 speed manual so that I can install an engine heater.
The instructions that came with the engine heater - which I bought at napa part number 605-3231 - state that it should be left rear of the engine near the oil filter. However, the only plug near the oil filter that I could locate is just below it and appears to be too small. The Haynes manual shows the non-threaded or punch style of freeze plugs and the one specified for my vehicle by napa is threaded. I was unable to locate a plug of either type. Any assistance would be greatly appreciated, it's already starting to get cold! |
RE: 1991 Accord EX Freeze Plug Location?
hi,
i own a 1992 accord model.My block heater is installed exactly where you mentioned. Notice that there is a drain tap/plug to drain the block.Unscrew it and install the block heater. good luck |
This has pictures for a F23, but it should be nearly identical for your car too:
http://www.driveaccord.net/forums/showthread.php?t=352 |
