1991 Accord SW, Engine choices?
Old Oct 9, 2012 | 01:49 PM
StPat's Avatar
Default 1991 Accord SW, Engine choices?
Hello all, I'm new to the forum, so if I screw up, be gentle.
I have a 1991 Accord SW with really bad engine trouble, will not turn over, oil runs out. What engines will interchange directly with this one? I realize a 1991 vintage engine is or would be best, but are there other choices? I'm in Alaska and don't have a good read on what is available. Thanks for any info and assistance.
Patrick
Old Oct 9, 2012 | 06:43 PM
Roader's Avatar
CB7 Tuner Forums has tons of examples of engine swaps for 4th Gen cars.
Old Oct 10, 2012 | 11:15 AM
StPat's Avatar
Thanks for the reply, I'll go there.
Patrick
Old Feb 3, 2013 | 04:04 PM
HondaAccord91's Avatar
Default Help with engine recognition.
1991 accord EX, with 213000 KMS.
Can someone please point me in the right direction as to what type of engine this is? And anything i should expect soon... as in things to replace. Most of the kms are driving from Montreal to Virginia Beach, and suburban driving by a man that is 95. one owner. If any advice is possible, i'd highly appreciate it.
Thank you,
Dimitri.
Attached Thumbnails 1991 Accord SW, Engine choices?-screen-shot-2013-02-03-4.53.49-pm.jpg
Old Feb 3, 2013 | 08:02 PM
Got any maintenance records? It should've gotten a new timing belt every 100k miles so you really should find out about that. Get that done if you can't find out.
Other maintenance is in the owner's manual, and again if you can't find records it might make sense to just do everything so you KNOW it's up-to-date. Spark plugs, antifreeze, valve-lash, etc.
It's an F22-something. Look at the split-line between engine & transmission, about mid-elevation. On the engine block alongside that split, there's a flat surface with the block serial # stamped in it. Top line is the engine type, something like F22A1.
Old Feb 4, 2013 | 12:25 PM
Thank you, very helpful.
Fixeruper
Jan 3, 2010 02:06 PM
Stanley9875
Mar 6, 2009 07:14 PM
BigShelby
Jun 17, 2008 08:38 PM
soccerboy08
Feb 4, 2008 05:00 PM
kevinyu1115
Apr 12, 2007 12:43 PM
