1993 Accord LX AT engine won't turn over
The only noise I get is a click inside under dash, which I'm assuming is the main relay. I loosened the fuel line bolt on top and when I turn key 'ON' I get fuel coming out. Does this eliminate the main relay? I do not get a click at the starter. Battery is good and connectors are clean. All the lights inside are good. I'm going to jump the clutch switch next. Any suggestions for what to check next?
Have someone turn the key to the start position and see if the smaller wire going to the starter gets 12V.
