1995 Accord Engine Shaking After Cooling Fans Turn On.
Hello,
I have a 1995 Accord EX with 105,000 miles. Every time the 2 cooling fans engage, the RPMs drop low enough to cause the engine to visibly shake (almost stall). Please help. Thank you |
RE: 1995 Accord Engine Shaking After Cooling Fans Turn On.
Hi Fredi..
I'm thinking that your fuelpump is not delivering sufficent fuel to the fuel injector system. I would start by checking that 1st... WheelBrokerAng |
I dont know man,
I'd check the electrical charging system first. |
Usually the 2nd fan is only engerized when the A/C is on. Compressor engagement usually increases the idle speed. Could be that: the A/C system is not functioning properly in conjunction with the fuel system.
:eek: |
The A/C was on at the time. Hopefully it won't turn out to be anything major. Thanks Guys for your input
RE: 1995 Accord Engine Shaking After Cooling Fans Turn On. A/C Overcharged???
I recently had my A/C system recharged at a shop. That's when all these strange symptoms started. I released A LOT of pressure from the system, but left just enough for the A/C to keep functioning. Now the car is now running fine when the A/C is on. The idle is actually consistent now. Before, there would be a single "bang" coming through the High Pressure A/C line before the cooling fans turned on, and then the idle would drop immediately. I'm thinking the system was overcharged. Thanks
great! i'm happy that it solved the problem ;)
glad that your problem is solved. my motor messed up on my cooling fan. not a cool thing. someone let me know what could have caused this.
ummmm......witchcraft!!! I think you've been cursed, my friend! ;)
i got it fixed. paid 80.00 for a new motor and made my dad put it in.
