1995 ex fuel issues
Ok so I know this will sound weird but I have had two of these cars a 94 ex and a 95 ex and the 95 ex will not accept more than 11 gallons of fuel period when it starts to stutter due to low fuel and it is also only at 1/4 tank when it does this what could possibly cause this I would like to have the other 6 gallons of capacity back but I'm not sure what's going on with it
I have a '97 so same size tank. Thinking it's a slightly smaller than norm size: more like a 14-15 gallon tank. Don't know the issue/fix ...
Had a friend with a Dodge that had a hole in tank, so he just kept tank between a 1/4 and 5/8+ tank so it wouldn't dribble out - drove it for years, even out of town. Annoyance, yes, but how much is it worth to remove the annoyance? LUCK. |
Sorry I'm a bit confused about what is going on from your post. Does the engine start stuttering when you get below 1/4 mark on the fuel gauge? Why can't you add more than 11 gallons to the tank?
Just a wild guess...
The fuel pump inlet fitting/screen has come loose, so when the tank is 1/4 full the pump begins to suck vapor. That's when it starts stuttering. Since there's 1/4 tank still in there, it only takes 11 gallons to fill it. |
Originally Posted by JimBlake
(Post 392788)
(Post 392788)
Originally Posted by PAhonda
(Post 392787)
