Sponsored by:
Sponsored by:
P1028 Code
Old 08-14-2011, 08:31 PM
Wayartio's Avatar
Default P1028 Code
I pulled the codes and the P0128 code came up. Air filter 55,000 miles and dirty. Could this be the problem. Thanks
Old 08-15-2011, 12:17 AM
This is a problem with the cooling system. You may have a problem with the engine coolant temperature sensor. Inspect the electrical connector for corrosion or damage. You should probably search the site and the web for honda accord p0128 to see how others have tested for this problem.
Old 08-16-2011, 09:03 AM
Wayartio's Avatar
Default P1028 Update
Thank you PAhonda for the help.After resetting the code another code which led to the ECT Sensor 2 came up. This is the sensor in the bottom of the radiator. I cleaned the connection and the high circuit resistance code has not come up again. As we live in Northern Illinois with salt and snow I believe this is a common problem and am going to buy a sensor and wire harness just in case as this harness leads to the cooling fan and must have come control over the fan. Thanks again!
chsriman
03-27-2013 04:33 PM
tingjunkie
09-17-2010 06:37 PM
will'i'am
09-16-2010 01:19 PM
Stener75
07-25-2010 08:21 PM
madsteez
01-18-2009 07:43 PM
Quick Reply: P1028 Code
