2015 Accord rear bearing replaced but ...
... on my dashboard I have 4 lights on after replacing rear passenger side bearing. ABS light is on, Flat tire blinks then goes steady, traction control light is on and steering issue light is coming on after few second of engine start. Any idea what might be wrong? I replaced bearing twice and 2nd time I also replaced the sensor. I reset all the codes/lights with a computer but all goes back after driving the car. Disconnected battery for about about 4 min but it didn’t help either. Can someone help me please?
Did you also calibrate the TPMS system afterward?
Your Accord comes with an indirect TPMS that doesn’t use tire pressure sensors mounted inside the tires. Instead, it uses the existing VSA wheel speed sensors to monitor and compare tire characteristics while driving.
Instructions for TPMS calibration is part of the owner’s manual and available online.
Having the code will help you pinpoint the issue. Being that you know the work you did caused the issue the code will help little. There are 4 things that will cause your issue ( wrong part/incorrectly installed , unplugged/broken sensor or recalibration). If you get the code do post it.
