1998 Accord - Brake flush
I plan to flush the brakes on my Daughter's 1998 Accord - 4 cyl, auto.
We had it for 6 years and wasn't flushed.
I read that I am supposed to use HONDA DOT 3 brake fluid. Is this true?
I can't use branded DOT 3?
or at least Prestone DOT 3 "for Hondas"?
If it doesn't matter, I can use Store brand DOT 3?
I wouldn't go that far. Lol. Really it's your choice. I always use Honda PS fluid if I don't have that I'll put other fluid in. The only thing I am particular about is the trans fluid. That I always use Honda no matter what.
PS fluid is different, so you can sometimes find fluid that says "FOR HONDA/ACURA" which is OK, but don't use the stuff that says for all cars. But actual Honda PS fluid isn't stupidly expensive either.
Auto-Trans fluid is different also.
For Hondas and Acuras with manual transmissions the consensus is ACDelco Synchromesh Friction Modified (formerly known as GM Synchromesh Friction Modified). Honda MTF makes many of their transmissions shift like crap, especially the 6-Speed units.
At least DoT3 brake fluid is the same, regardless of who makes it.
