1998 accord idle surge. Help!!!!!
My car is a 1998 Honda Accord ex 2.3l vtec with standard trans. My idle is surging and I don't know what else to do. I have replaced to iac, tps, map sensor, throttle body. I have 3 stepped it, burped the cooling system, did a couple idle relearns, checked for vacuum leaks and then double checked for vacuum leaks.
When it first happened I got a 1590 code (iac circuit malfunction) and then the fun started. I replaced the iac ( all new parts nothing used or from a junk yard) and nothing changed. Then I kept replacing parts and nothing has changed at all. Starting to think of its the Pcm. I really need help. I'm loosing my mind over this car. Any ideas would be great. Thank you so much for your time |
Are you still getting the P1590 code?
Originally Posted by PAhonda
(Post 367122)
1998 accord 2.3l 5sp weird idle surge
Ok so my car idle is surging. When I start the car it will idle around 2k for a couple min. Then it will go into a surge. It will idle between 1 and 2k. I have noticed if I rev the car over 5k (quick rev) the surge will go away and idle perfect. It will hold a perfect idle until I start driving again.
I have replace the following. Iac valve Tps Map sensor Throttle body Coolant temp sensor No vacuum leaks at all I have burped out the cooling system to many time to count. I have also pulled the number 13 fuse and tried a idle relearn. I'm running out of ideas here. Is it the pcm? Are there any other test to do? It's driving me crazy. Thank you for your time. Josh |
Is there some slight slack in the throttle cable allowing the throttle plate to close completely? When the car surges at idle, try twisting where the cable turns the throttle plate backwards to see if something is getting caught up.
I also merged to your other thread, so we don't have two different threads trying to diagnose the same problem.
(Post 367147)
You need some slight slack to allow the throttle plate to close completely.
On my old 95 accord, I didn't get the cruise control cable installed properly when reinstalling my throttle body. It was preventing the throttle plate from closing completely and causing idle problems. Its something simple to check as well. |
EDIT: I also moved some other posts from another thread about a 2000 V6 issues into this one so there might be some confusing timelines, posts in this but at least the one issue is in one thread.
I'd recheck the work done on the car just to be sure......throttle cable has to correct amount of slack, TB gasket is good, ect. I'll assume the bouncing only happens once that car is warmed up, normal op temp. If you cover the lower port inside of the TB with your fingers, what does the idle do....no change, lowers but still bounces, lowers and the bouncing stops, ect. |
(Post 367153)
I'd recheck the work done on the car just to be sure......throttle cable has to correct amount of slack, TB gasket is good, ect. I'll assume the bouncing only happens once that car is warmed up, normal op temp. If you cover the lower port inside of the TB with your fingers, what does the idle do....no change, lowers but still bounces, lowers and the bouncing stops, ect. If I cove the hole closest to the passenger side the car will idle very low and the sure will stop. It looks like that's the hole for the tps. By covering it slightly the car will idle fine and everything is ok until I uncover it. I do have a snap on scan tool hooked up to it and the specs on the you are perfect |
| All times are GMT -5. The time now is 02:13 AM. |
