dineromike1 |
05-26-2010 10:10 AM |
1999 accord crank position sensor no signal
I'm workin on my buddys 99 accord and checked the code which is p1382 (crank position sensor no signal. Only # 1 cylinder is firing and 2,3,and 4 r dead. Changed crank sensor changed disturbuter.... Same ****! Put jumper harness from obd II to obd I w/ a civic sd computer and same ****! Narrowed it down to a short somewhere. Idk if this is a common problem on accords or what. Help me out please. I don't work on accords much so that's why I'm on here.
