1999 Accord Wonít Start - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Old 06-13-2018, 05:28 PM
Default 1999 Accord Wonít Start
I have a 1999 Accord 4-dr EX. I had the CEL on and thought I could manually pull the CEL code by using a paper clip to the OBD2 connector, which Iíve done several times in the past, but apparently didnít do it correctly this time, as I sparked the connector, which now the car will still turn over, but wonít start. All fuses are good. I hope itís not the ECU/PCM, any thoughts besides calling me an idiot for not taking it in to get the code read?
Thanks!
Old 06-13-2018, 10:11 PM
What wire colors did you accidentally short?
Old 06-14-2018, 07:40 AM
Iím not sure as I donít recall which pin holes I inserted the clip in when it sparked. I looked on the backside of the connector where the wires insert, but I canít tell which wire(s) got fried just by looking at it.
Old 06-15-2018, 11:31 AM
Under-hood Fuse No. 46 (15A) is probably blown. Hopefully, that is the only damage.
That fuse provides power to & protects the DLC - Data Link Connector (OBD connector) and the Main Relay.
Old 06-16-2018, 09:36 PM
Well, you ARE correct, thatís exactly what it was. Thanks so much!
Reply
Dbeemen
11-01-2015 12:12 PM
Sheri6889
06-17-2015 08:19 AM
polarihog
02-17-2012 05:54 AM
josh.roy35
09-23-2011 07:39 PM
josh.roy35
04-26-2011 01:56 PM
Advertising
