Jet sitter |
03-26-2019 06:09 PM |
2000 2.3 with ABS light on CEL 53-1
My ABS light came on today. Checked code and it's the 53-1 ABS module. I looked at the fuse and there were dark marks (arching) on the pins, but the fuse was still good. Replaced it with another 7.5 amp fuse. Light still on, pulled both electrical connectors sprayed electric cleaner on the pins and receivers, CEL remained on. I checked google and the most common cause of that CEL is the electric motor on the pump. Has anyone had any experience with this problem? Appreciate your expertise, thanks. If you guys agree with google, I'm thinking of pulling the motor and cleaning the armature and installing new brushes.
