2000 Accord radio error taking out radio
Old Feb 10, 2009 | 03:18 PM
RecMK5
Default 2000 Accord radio error taking out radio
How do i take the radio out? and its the serial #'s in the back? which buttons do i press to put the # in?
if anyone knows thanks!!!
Old Feb 10, 2009 | 03:25 PM
finch13's Avatar
Go to installdr.com or search, it's very easy to do.
The radio serial number and the radio anti-theft code are NOT the same number. The code is 4-5 digits long and should be with the owners manual and vehicle info stuff.
Old Feb 10, 2009 | 03:46 PM
hondadude's Avatar
You should be able to press and hold the 'one' and 'six' buttons while turning on the radio. Then a number set will display, press them again and then you should have the "REF" number. With that info the dealer should be able to get you the code
Old Feb 11, 2009 | 01:12 AM
RecMK5
i tried holding 1 and 6 then turning the radio on but the error still comes up nothing new.
and theres no # in manual the manual is for a different one i think.
one of the bolts holding the radio in place is stripped but there is a # written in the dash when i took it off 8020
Old Feb 11, 2009 | 07:07 AM
Try using that 8020 as the radio security code?
The radio security code is originally supplied on a little plastic card (size of a credit card) inside the owner's manual package. You're supposed to keep that someplace else, not in the car... Then most people forget about it when they sell the car.
Lots of dealers write that number someplace, but not always & not in the same place.
Old Feb 11, 2009 | 01:14 PM
RecMK5
where can i put that code in?
or do i call the dealer and give that to them?
Old Feb 11, 2009 | 04:16 PM
Looking at your original post, it's a bit confusing. I thought you were looking for the security code which you enter into the radio (using the station buttons) after you have disconnected power.
What are you actually trying to do?
Old Feb 11, 2009 | 08:43 PM
RecMK5
Yeah its my girlfriends accord.
the error is coming up on the radio
i could not look behind the radio but there was 8020 written inside above
the radio.
D/c the battery?
Old Feb 12, 2009 | 06:40 AM
So the display shows "ERROR"? Is there more, like an error number?
Normally (if there's no error) after you disconnect the battery, the radio will display "CODE" & you have to enter that security code.
Old Feb 12, 2009 | 07:12 PM
RecMK5
only #'s i seen was 8020 but theres only 1-6
