2000 Honda Accord LX shock absorber removal?
I need help guys, I need to replace my shock absorber, anyone knows a good DIY guide with pictures? I need the one from a service manual. Thanks!
RE: 2000 Honda Accord LX shock absorber removal?
Well you have springs... you must have had them put on somewhere or bought the car with them...
http://www.filtsai.com/accord/suspension/index.php |
Will it be the same procedure especially in putting those parts together? My car is currently making a like a "knock" sound from the right rear shock whenever I hit a dip, I'm guessing the guy who installed the shocks didn't do it right. So I need to disassemble and put it back together again, but I need to know how the exact and correct way of putting it together.
Thanks much. |
From the uneasy tone I'm getting from yuor posts, I'm going to say that you should have a mechanic do it. Also, it's best to replace shocks and springs in pairs or quads like tires.
If you feel comfortable doing it yourself, I can help you step-by-step with diagrams. You will need to compress the spring with a rented spring compressor. All in all it's not a terrible job, you just need a lot of penetrating oil/WD-40 to free up rusted bolts :D
Knocking noises from the suspension is somewhat typical of lowered cars. I have a feeling that the piece or rubber between the spring and mount has worn through making a metal-on-metal knock. Do you know if they are aftermarket shocks? Aftermarket ones are usually yellow, red or blue, while the stock ones are black and have "SHOWA" written on them. |
Finch13...yes they are aftermarket, they are KYB shocks, the odd thing about this is it only knock on the right back side. I'm thinking maybe my brother-in-law didn't put it back right. I actually just need the picture on how the shock should be assembled including those rubber thing, so I can show him how it should be.
Many thanks. |
http://www.hondapartscheap.com/south...13S840_B30.gif
The rubber part is #10 in the picture. They are special order at Honda with part number 52686-S84-A01. They shouldn't cost you more than $5/ea and I actually have a full set on order from Honda right now.... which reminds me to call them and ask why they aren't in... |
Is this for the back shocks?
Yep, you said right back side. Do you need the front as well?
No it's fine, thanks so much for your help. Appreciate it :)
