2000 Honda Accord Mirror issues
Ok,
So I have replaced the switch and multiplex units. Mirrors move up and down, but won't move left or right. I find it hard to believe that both gears went out at same time. Any ideas?
Thanks,
James
Thanks,
James
Yes, I have tested new switch. the problem gets more confusing because the old switch did the same thing. Now, the mirrors work only when they want too....LOL One minute they work, the next they don't one minute they will move up and down or even left and right and the next minute they won't again same with the new switch and the old switch. Hope this clarifies things.
James
James
I willl check the wires to see if I can see anything. Anyone know how I can test the mirror themselves to make sure the mirror motoers/gears are still good. I tried using them today, like I said they work for 3 seconds then stop, awhile later they work for a few seconds then stop. Driving me crazy!!
Thanks for the help.
Here is a diagram showing how to test the switch, you can use this same diagram to know which wires to jump to make them move.
Then I have to ask, why are having to adjust the mirrors so much.....I can't remember the last time I adjusted mine.
I check switch again, its good. I will attempt to jump mirrors like you suggested. To answer your other question 3 people drive vehicle so mirror adjust happens often. Still checking door jam as well, will get back to you with what I find.
