2000 Honda Accord problem plz help
so today in the morning I want to go home and I unlock my car and open my door and my alarm goes off and I keep pressing the button on my remote and nothing would happen so I open the hood to take the fuse off and the battery and after awhile the car won't turn on can someone give me a suggestion on what to do :)
will it do anything? anything still coming on? or does it seem as if battery is dead?
I moved your post to get some attention. Pegging to a 6-yr old dead end post won't help your problem.
Alarm going off can be as simple as weak battery. If you remember, the alarm will go off when you remove the battery cable. Simlarly it will go off if battery voltage goes too low. Clean/inspect battery posts and have battery tested. good luck |
Thats exactly where i was goin with that
I just know that you checked your remotes battery or didn't you.?
I can't turn the alarm horn off
I changed the battery of my remote
did you check the cars battery?
