2001 accord 2.3l vtec main bearing bolts torque
Hello. I searched but could not find a post for the Main Bearing Caps/baffle torque specs. Anyone??? Thanks
Your thread has been moved from the DIY section. Please do not post help questions in the DIY section.
If you are talking about the 11mm bolts you first tighten them to 22ft/lbs then 58ft/tlbs
In this order: 10 4 2 6 8 This is the transmission side of the engine 7 5 1 3 9 the 6mm bolts are the same order but 8.7ft/lbs. |
