2002 Honda Accord v6 AC clutch not engaging
My 2002 Honda Accord by ac clutch not engaging when I turn the ac on, so only warm blows. Clutch engages when I jump the ac clutch relay and there's cold air then. Electrical shop said it was the evaporator temp sensor which I replaced but no change. I also purchased the expansion valve but hesitant to replace before I am certain. Only 2 wires read 14v at the clutch relay and the other 2 reads 0, so there's no ground coming to the ac relay. Swapped relay with horn relay and it is fine. Also, the blower switch next to the evap case behind the dash reads 14v on the black/yellow wire but 0 on the red/blue wire so there'sno ground there as well. 35 psi of pressure on the low side when ac is turned on and the clutch is engaged. Can anyone help, I am stomped?
Originally Posted by DaGoat
(Post 382528)
I had a friend that has a 2000 3.0 and I tried everything then put attention to he head unit. When I changed it everything worked like it should. Just throwing that out there not saying that is your problem.
Didn't understand your response
The climate control was my friends issue. Once I changed it everything started working
Originally Posted by Seanjordan20
(Post 382537)
I checked that and everything is working fine. I just have no ground going to the clutch relay.
Have you checked to make sure your pressure switch was good?
