2003 Accord OBD connector
My 2003 Accord failed inspection in NJ do to OBD connector. What or where can I locate in the car?
OBD Connector
Most all honda cars have the location of OBD 2 connector under the base of the steering wheel. just put your head under steering wheel and look up just behind the steering wheel. white sticker with black type.
its bellow the steering wheel on left side above foot well just below trim pannel
Have your system checked by another scanner to see if it works. I've heard of faulty OBD2 connector on inspection service scanner failing and causing them to suspect car instead of their equipment.
good luck |
Thanks. I will do this.
I will check this out.
Thanks. |
Great!!!!!! I will check it out........
Yes let us know what you found out..I moved this to this forum... :)
(Post 234664)
good luck ODB2 connector thanks to an annual inspector pushing hard enough to break it loose. A little silicone calk along the sides fixed it, and made it usable. God bless the USA and hope you all stay healthy, Jim US Army (retired) |
